My heater seems to be to cold and temp gauge stays very low, also steering seems very sloppy, any ideas, I am new to Kia Cars
The thermostat is below the filler cap on the Diesel motor. Just as an idea have you tried ringing up the local Kia dealer and asking to speak to the workshop? sometimes they are helpful and other times you get some neanderthal who worked on a Model T and still thinks he is.I know we have been around this buoy before but I cannot get anywhere with an airlock in my 2001 Sedonna 2.9 TDI. I recently had one of the rear heater pipes go just above the spare wheel and replaced the two which were corroded with rubber pipes. It all worked fine but what I did do was to fill the car up with water and test it while the rear was up in the air on the ramps. I therefore assume I introduced an air lock in to the system. I tried everything (both heaters on whilst running, massaging the pipes even taking the rear return pipe off with engine running but the airlock will not budge) I subsequently took the bottom hose off the radiator and put the front of the car on the ramps to drain the system down and ensure the front of the car was the high point and refilled it with water. Still the thing seems to be air locked and now the front heater only works intermittently. Sometimes the heater works and sometimes it doesn't but when it does get going and we are on a run it is fine. Until then the thing is intermittent. The rear heater rarely gets warm.
The water that came out was not particularly dirty or sludgy and when I had the bottom hose off I put it back on and filled up a couple of times and let it back off again to flush any sludge that might have built up out, but I didn't see any. I also noticed that the temperature gauge is a bit erratic now. I have ordered a thermostat and am going to fit that this weekend just in case along with another ÂŁ5 of antifreeze...!! I assume the thermostat is in the housing just below the pressure cap? I suspect the thermostat might be having a bearing on the problem but it is being masked due to the cold weather and the fact that we are only undertaking short journeys at the moment.
My main question does anyone have any ideas for getting this air lock out? Should I draw the whole system down and start again? Is there a good way to fill it back up again? Engine running maybe? This air lock is doing my head in especially in the freezing cold.
Garteful for any advice.
Hi MikeI think I might be in for some bad news with my Sedona. A little while ago one of the rear pipes went and the car ran dry for about 12 miles. I did the pipe and all went well except the rear heater didn't work. Then it appeared to be air locked and the front heater and temperature guage became a bit erratic. So i changed the thermostat. This hasn't really helped and when I look in the header water bottle there is a constant flow of little bubbles coming from the feeder pipe. I think with the car having overheated when the pipe split and the ongoing water problems and bubbles it is almost inevitable that the head gasket has gone, after all them bubbles have got to be coming from somewhere pressurised like the cylinder.
I would be grateful for anyone elses opinion though?
I called a couple of dealers (lincoln and Grantham) and both said they would be able to do the head gasket for ÂŁ650ish. Oh My GOD...!!! The gasket set costs ÂŁ60.00 off e-bay. Does anyone know how hard it is to do the head gasket and whether any specialist tools are required?
Many thanks for any advice.
Mike
